I was going to say that I'd have thought the pulse frequency would be much too high (1000Hz+) but then I guess that would still cause problems with something spinning at the right [wrong] rpm.phil.p":2h9sqfxc said:I have LEDs over my lathe that strobe.
Interesting - didn't know that; thanks.woodaxed":2h9sqfxc said:the rule used to be fit twin tubes with moving machinery as one tube cancels the others strobe effect
My dodgy understanding of electronics makes we wonder if some capacitance in the system may be introducing a phase shift, such that two bulbs in one fitting will pulse with an offset from one another (same frequency, but just at different parts of the "wave").. Wild speculation on my part.phil.p":1x3nuaxn said:Surely if both tubes ran off the same phase they'd strobe just the same? I can see the point of wiring two or three series of them on two or three phases in a huge place to avoid this.
woodaxed":1ajya9s8 said:Any issues with fluorescent lighting and machinery? I'm thinking of 50Hz strobing
phil.p":2spe762k said:Allelomimesis. That's one for your pub quiz. It's when birds or animals all do the same thing at the same time, like flocks of starlings changing direction instantly. By the bye.What's the TEE formation?
Tonytygwyn":1x5wloee said:Does anyone know where this would be situated and how it would be wired? As there is very little info on the Felder website. I'm guessing near the distribution board
http://uk.feldershop.com/en/Extraction/ ... -oxid.html
with my limited electrical knowledge you wire one on these into the control unit and place the transformer coil around each machine feed wire that you want to start the dust extraction.
http://uk.feldershop.com/en/Extraction/ ... start.html
Any help would be appreciated.
