Well, I did some more investigating after recent suggestions.....my theory has now changed, but I'm keen for any thoughts you guys might have!
I listened to the bearings using the long screwdriver method, and they seemed ok.....just a gentle whooshing sound, with no indication of rumble or vibration. Not conclusive, but a good start.
I then looked at all the moving parts in a bright light, with and without the blade fitted. It looks to me like the tyre on the upper wheel is not exactly round. The blade rises and falls slightly looking across the top of the wheel whilst in motion.....not be much, but I'm convinced it is visible.
This in turn would put an oscillation into the blade, which might excite a vibration in the frame. My current theory at least.
I tried to measure the irregularity of the tyre with a dial test indicator, but failed dismally, so unfortunately I can't put a figure on it. But it is visible....a fraction of a millimeter for sure, but visible.
Anyone have any thoughts on this? Moreover, anyone have any tips on tyre replacement? These are rubber bonded on ones, so does that mean a professional refit job?
All the best
Graeme
