Alexam
Bandsaw Boxmaker
woodpig":2pryoqk3 said:As you mentioned earlier you're going to need some pretty thin shim stock to attempt to correct the error. Probably worth getting or making a hole punch as well so you can make thin washers as shims just put in place would be guaranteed to move or fall out if I did it!
I read somewhere that if very thin shims are needed, best to buy a set of feller guages and use them for the shims. Not very expensive and saves trying to find material thin enough.
http://www.halfords.com/workshop-tools/ ... -16-blades
