@Nail Have a look on Axminster tools site they have a few after market replacement bandsaw guides, some even with the correct orientation for a bearing: Bandsaw Accessories - Sawing - Machinery Accessories - Accessories | Axminster Tools
Yeah, I’ve seen them. I’m just too tight to buy them.@Nail Have a look on Axminster tools site they have a few after market replacement bandsaw guides, some even with the correct orientation for a bearing: Bandsaw Accessories - Sawing - Machinery Accessories - Accessories | Axminster Tools
Is that a joke,I only ask as it's very hard to see,if it is or not,tell me when to laughI really fancy a couple of support legs, I've been changing the front springs on my car today and all the kneeling and getting up and down (I don't have fancy ramps, just a jack), plays havoc with my knees.
Ok,I looesend the m8 nut on column as someone said it was a cam bolt,which would give 5mm clearance,but I got nothing from it!Can we see if the guide mounting shaft itself, can be adjusted?
Is there a solid steel guidepost, with bracket to house it,
I guess it might be possible... somehow.
Tom
Here you go!The last picture you put up - can you do a picture from the other side.
Have tried that but it then hits the steel shaft beside it!Just move the thrust bearing behind the side bearing
So move the housing forward on the steel shaft.Have tried that but it then hits the steel shaft beside it!
You can only move it forward so much,given the blade is in the correct place! The thrust bearing will still.have to moved back and still hit the lower side bearing,and/or the steel shaft!So move the housing forward on the steel shaft.
