What bar are you referring to?Is the hole in the thrust bearing central? If the bar is rotated does it change the position to the blade and lower bearings?
The bar that the bearing is inWhat bar are you referring to?
Ok there's no joy there I'm afraid,nothing!The bar that the bearing is in
What I was told here is,i think, is the m8.bolt at rear of column is offset and if I release it I could move it about 5mm,but I don't see that!And the peg for the bearing that goes into the bar is central?
It would make sense that one is offset.
Pics of both would be good.
You’re talking about something different to what I’m asking about.What I was told here is,i think, is the m8.bolt at rear of column is offset and if I release it I could move it about 5mm,but I don't see that!
Ok,there's no offset in pegs or bar that guide is in!!You’re talking about something different to what I’m asking about.
I’m talking about the bits in the pic I posted.
And all appears central!Ok,there's no offset in pegs or bar that guide is in!!
Hi,thank you,I will have a look at that tomorrow and see how I get on!Looking at the various images you've posted:
This one shows that the whole guide block is too far to the right, hence the left guide being fully extended and the right guide interfering with the rear guide.
With the following picture, unless it is the angle of the photograph, it looks like there is an offset pin between the bolt at the rear and the guide block (circled in red).
So try loosening the M8 bolt at the rear, and the the grub screw circled in red in the picture below and see if you can rotate the offset pin to move the guide block to the right (you will need to loosen the left and right guides first. If you can manage this, adjust the right guide and rear guide so that they don't interfere with each other and align the guide block so that the left and right guides are roughly equal to the blade.
Actually about the offset screw is it the front piece attached to the housing,or the back piece attatched to the M8 bolt?Hi,thank you,I will have a look at that tomorrow and see how I get on!
You’ll need to adjust both.Actually about the offset screw is it the front piece attached to the housing,or the back piece attatched to the M8 bolt?
