Bagpress Adapter
Ian
5 Apr 2007
Northern Ireland
Hi All
I have a mini bagpress and the bag & adapter got damaged by the dog (long story)
Anyway the bag was ok as I could cut of the damaged piece, however the green bag connector and push fit adapter was in bits and I need a new one.
I was hoping to get them from someone other than bagpress as their delivery charges are quite high, I have searched under google but can't seem to get the green bag connector.
Ian
Ian, do you mean the little plastic 'O' type affair? Where the tube is simply a push fit?
What size tube do you have?
If this is what you mean, I have an 8mm (I think, though it could just as easily be 6mm) that I could post to you.
Let me know if this is what you're after and I'll search the shed.
Adam.
Thanks Adam, I need the bit thats makes the hole in the bag and the piece that screws into it.
http://shop.instant-shop.com/bagpress/p ... 50374.html
I remember when I first got the bag it had a 2 part green disc, one part goes inside and the other outside. Then there was a quick release pushfit which the tube fits into, this screwed into the green disc.
I need the green disc and the pushfit
Thanks anyway
Ian
