Raymond UK
It's the AC216TS in the catalogue. The TS250 is not in there though.
It has the same 1100W motor as well.MikeJhn":na9n8yj9 said:The AC216TS only has a 216mm blade, so I assume it is the replacement for the TS200 which had a 200mm blade, if the TS250 is missing from the catalogue I also assume the replacement for it is just around the corner, I suppose the reason its still on the web site is because they have some to get rid of and will not add the replacement to the web site or catalogue until they have sold them, seems very mean and they should be offering them at a substantial discount.
If you can get away with the depth of cut of the new Axy model I'd wait for that. The 'proper' 19mm slots, proper trunnion setup etc. Would be worth having.Raymond UK":1fmzwkij said:Ive not seen the package deal.
I think it was about £680 with the extension and slider.
With a bit of luck the TS250 will still be in stock with the sliding table and extension table. Probably get some legs until I make some suitable base to sit it on.
Bodgers":24jpwvjs said:If you can get away with the depth of cut of the new Axy model I'd wait for that. The 'proper' 19mm slots, proper trunnion setup etc. Would be worth having.Raymond UK":24jpwvjs said:Ive not seen the package deal.
I wasn't convinced until I saw the details, but I'm almost convinced to buy a TS again now.
Sent from my Redmi Note 5 using Tapatalk
Bodgers":2mc3gdjg said:It has the same 1100W motor as well.MikeJhn":2mc3gdjg said:The AC216TS only has a 216mm blade, so I assume it is the replacement for the TS200 which had a 200mm blade, if the TS250 is missing from the catalogue I also assume the replacement for it is just around the corner, I suppose the reason its still on the web site is because they have some to get rid of and will not add the replacement to the web site or catalogue until they have sold them, seems very mean and they should be offering them at a substantial discount.
MikeJhn":h07x9q72 said:Bodgers":h07x9q72 said:It has the same 1100W motor as well.MikeJhn":h07x9q72 said:The AC216TS only has a 216mm blade, so I assume it is the replacement for the TS200 which had a 200mm blade, if the TS250 is missing from the catalogue I also assume the replacement for it is just around the corner, I suppose the reason its still on the web site is because they have some to get rid of and will not add the replacement to the web site or catalogue until they have sold them, seems very mean and they should be offering them at a substantial discount.
Same motor, larger blade, Hmmm
Sent from my dinning room table using my laptop. :roll:
As others have pointed out it's really surprising that none of the major manufacturers have latched onto the problem of dust collection in general, and your idea in particular. The unit cost of attaching something like the dust hood to their machines would be relatively trivial and in any case could be recouped by the selling point of having superior extraction.MikeJhn":3dnjzo8x said:The main problem with all table saws is that there is no collection or direction to the outlet, putting any type of dust deflection piece like the big dust hood inside will help direct any dust to the outlet, so in short Yes.
RichardG":35hx8gi1 said:The stand is made from 4x2. I made my own dust collector underneath the saw and re-used the included 100mm plastic connector. I found that not removing the side of the blade guard didn't seem to harm the dust extraction so I left it on but removed the hose. I covered the gaps around the table to body using rigid foam and then magnetic sheet to cover any other holes. Note I left the gaps round the height adjuster so there's an air flow through the machine.
