I've just fitted my Extreme Xtension to the table and as far as I can ascertain, it looks like a good'un :wink: The inner grey insert ring on the table itself had to be filed down to clear the side of the Xtension. On spinning up the router, there was no, say again,
no out of balance or wobbliness in any way, it's perfectly balanced...and that was spinning the router at the highest speed. As all the adjustments can now take place above the table:
a little bit of accurate work with some 12mm birch ply and the lathe turned the original Trend socket thingie into a much better 'spinner to raise and lower the router through the table. As a brucie bonus, an adapter is supplied :
so that you can use all your 1/4 inch bits in the router table for light cuts, shown for 'foto purposes only here! I'd hesitate to suggest that you'd use the smaller bits for big cuts, but for finer stuff it ought to be fine.
As far as I can make out, this is a really great bit of kit and if you haven't get one...get one! ('cept he's now out of stock
Edit - there is no need to '
set up' or install the thing...stuff in a
clean collet on the router, tighten up and file out the insert ring (if required) Took me round about 20 mins to get it running and then a further hour or so to make the adapter for the 'spinner' - Rob
