Price may be going up but component quality is definitely going down. It looks the same as it always did but the bits inside are nowhere near as good as they used to be. They are fast approaching a similar position with regards quality and reliability of the kit they sells as I hold Rutlands to be at. Yes Axi have always had good to very good customer service but I don't buy things to have a relationship with a company's customer service department but to avoid it completely
I'd have to agree - late 2018 I bought a 2nd hand Axi 200mm tabletop saw being advertised here, that was only a couple of years old and had seen almost no use "because I couldn't get on with it", I looked it over at the sellers place, but didn't give it a white glove inspection - It's an axminster right so should be just fine.. how wrong was I? I paid top price too for the same "it's an axminster" reason.
The fence WILL NOT set to 90deg to the table no matter what I do - I don't mean parallel to the blade, I mean the vertical face of the fence, it's off vertical by maybe 5 deg, and this is thier so called "improved" fence design over the old one copied from Kity (which btw is very good) - seller also confessed it was the SECOND cast iron top as the first one was warped and had to be replaced, and lastly the central blade aluminium cut out... doesn't even fit very nicely. The oval shape isn't oval, it's rough as though the person hand finishing (I can see the file marks on it) it didn't give a monkeys, and the holes drilled to screw it to the cast iron top are misaligned, therefore the screws do not bed properly into the countersinks, so screw heads are sticking proud of the bed, right where you would push the wood through. No wonder the original purchaser "couldn't get on with it" and not his fault he was a novice who didn't really understand the issues to get them fixed after purchase.
It's a "tablesaw shaped object" (so I can't even in good conscience sell it on again and keep my Kity 419 instead of replacing it) and I've so far yet to use it while I have a Kity on hand. I bought the axminster as I thought it would be superior to the Kity, and it is in two ways - a separate handle for the tilt mechanism (the Kity one is prone to issues using one handle for both operations and a plastic handle that loses grip) and a quieter motor, but the issues with the axi (especially the fence) will require more money and time thrown at it just to fix the issues that should not even have passed quality control.
This experience alone means I'll not be buying anything of "axminsters" - sorry, chinese rebadged - machines anytime soon, if ever.
Oh and their "Guranteed flat for it's lifetime" (according to the sales page) laminated plywood, formica covered router table top - wasn't flat - edge to centre there's a 3mm camber, not 0.3mm, 3mm according to thier own axminster, certified steel straightedge, which is one of the few things I've had from them I'm happy with.
This one - £200 and it's ffing WARPED
UJK Professional Laminated Router Table Top
