axminster AWVFS problem
robdguk
6 Jan 2010
I was bought an axminster AWVFS variable speed as a birthday present just over a year ago, but I haven't had much time to use it.
I carve lovespoons so a fretsaw seemed like a god send. i ordered a load of pinless blades and after using the saw on 3 occasions found that the hex bolt that secures the blades to the upper arm of the saw was very soft (a problem I found with the axminster sabre saw.2 failed with soft bolts and one was replaced under warranty). the hex slot has worn too much to be of any use at all.
I know I can use pinned blades, but they aren't suitable for some of the smaller work that I do.
So, does anyone know anything about the olson conversion kit? or should I just replace the bolt with a higher quality hex bolt?
Rob
Hi Rob,
I had the same problem - if you have ebay account have a look at a seller called DSJ-Hardware here for replacement bolts.
I can't remember the size now but look under the Black Grade 12.9 socket cap - they are certainly better quality and last a lot longer!
Dave
PS Olsen fitting instructions here (link is just below the add to cart button)
Daven, Thanks for posting..
I have received the hex bolts from DSJ (they are M4 x 16 BTW and are much higher quality than the originals) and now I'm back in business
Much appreciated
Rob
The rear tension rod on my school workshop SFS 24 has sheared. I will cut a bit off, tap out a spacer and braze or locktight it. Then rebuild the lower arm assembly.
Much appreciated
Rob
I found they last ages - and for the price it doesn't matter anyway! :lol:
I have just odered new bellows for the blower from Axi - they were only a couple of quid each but they still wanted £4 for delivery so had to wait until I needed more bits! (not kept in stock either!)
Mike - good luck with that!
Dave
I tried to remove the bottom bearing. The big nuts are neither metric, nor any form of imperial spanner. I have had to open up an old Britool file to match the nut.
