G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
Why don't they work on woodworkers tools? Don't you use them on nicked edges or are you lucky enough to have one of the big ol' wheels?
They do but they hollow grind too much and tend to over heat too easily. It's what we used to do at school and drive the woodwork teacher mad! Bench grinders were in the workshop for the metal workers who shared it.G S Haydon":3trlypjr said:Why don't they work on woodworkers tools?
No I use a belt sander. Or a coarse stone on smaller bladesDon't you use them on nicked edges or are you lucky enough to have one of the big ol' wheels?
Avoid the gadgets and get more practice in or you will never get it right. Simples. Save the gadgets until you have given up all hope!wizard":37102fia said:If you do not have the skill then by the gadget simples
Jacob":4e3mspug said:No I use a belt sander.
I'm another of those (generally) hollow grinder types, with a slightly higher honing angle Jacob. Back in the old days, well when I was young and learning, which I guess is old compared to quite a few here, we just didn't get very fussy about sharpening chisels and plane blades and the like. We had a simple grinding angle and honing angle thing going on -- those angles may have been 25º and 30º, but I don't know for sure as it wasn't something we measured; we simply eyeballed it for 'right'. We used whatever was to hand to create the grinding angle, e.g., bench grindstone, belt sander, linisher, one of those oil drip circular stones that ran flat, and even something like a concrete step or similar if push came to shove, etc. There seems to have been a bit of a fashion developed over the last twenty or so years for 'primary' bevels and 'secondary' bevels... and even something called a 'micro' bevel, which seems to be an additional bevel to the 'secondary' bevel.Jacob":3ke3k2cc said:That's odd - carvers work bevel down most of the time and prefer convex bevels. A hollow ground bevel with a micro edge would be difficult bevel down - the convexity gives you control.
The Sorby Pro Edge is a belt sander but designed for sharpening..bugbear":1seaznrj said:Jacob":1seaznrj said:No I use a belt sander.
You said you sold the belt sander, and bought a gadget, sorry "Sorby Pro Edge".
BugBear
Jacob":24cy601s said:The Sorby Pro Edge is a belt sander but designed for sharpening..bugbear":24cy601s said:Jacob":24cy601s said:No I use a belt sander.
BugBear
An ordinary belt sander will do but not so conveniently and there is a fire risk due to the sparks, dust, and plastic enclosed spaces.
Jacob":1pu2q03u said:That's odd - carvers work bevel down most of the time and prefer convex bevels. A hollow ground bevel with a micro edge would be difficult bevel down - the convexity gives you control.G S Haydon":1pu2q03u said:..... From my experience the only trouble I find with the convex bevel on chisels is during bevel down work.
David C":2ku12erb said:High finger pressure on one edge and low pressure on the other will bring a chisel towards squareness, with each stroke on a coarse stone.
Dunno it's only a common or garden linisher but adapted slightly for sharpening purposes. Well made though. I only use it with coarser grits for re shaping as I find sharpening easier freehand on flat stones.G S Haydon":2s9yuxyp said:Wow, that sorby concept is quite a thing. .....
