Maybe not for 200 pieces though.Although not as accurate a multi tool is good for cutting most plastics due to the finer blades , speed control makes it even better imho
That is a generous offer!There are two varieties of acrylic, cast and extruded. Cast Acrylic is more forgiving and less prone to cracking, extruded acrylic is more accurate but has a lot of inbuilt stresses.
The best way to cut Acrylic is with a laser cutter which doesn't have to cost a fortune and would be worthwhile for a large number of cuts. If you fancy taking a trip to Gainsborough, you can use mine.
I respectfully suggest that you have that the wrong way around.There are two varieties of acrylic, cast and extruded. Cast Acrylic is more forgiving and less prone to cracking, extruded acrylic is more accurate but has a lot of inbuilt stresses.
No problem, I only speak from experience of laser cutting and routing Acrylic.I respectfully suggest that you have that the wrong way around.
I was told and it seemed to be true that extruded was more accurate due to the way it's manufactured, the acrylic being forced through a dye. Cast Acrylic not being formed through a dye isnt as consistent. The tolerances on thickness were always better on extruded when I checked.Cast and extruded are very different materials, cast being produced in small batches / sizes with a far better surface finish and clarity as well as better chemical resistance. It is also manufactured to tighter thickness tolerances than extruded, that being my point.
Yes they do BUT extruded is dreadful for routing, you end up with Acrylic toffee on the cutter and cuts aren't clean. Cast machines way better with much cleaner cuts and finishes. Laser cutting is fine on either but the extruded can often show stress crack after a couple of days, cast has no such issues.Extruded is exactly as described, faster production on continuous rolls then chopped off to length. You can see the ripple effect extrusion marks if you look closely. It is generally cheaper and most suitable for thermoforming as easier to work than cast. Both materials will crack and craze if best practice isn't followed when cutting, drilling and machining.
Aye, I too have seen Acrylic in the making and made in excess of 22,000 of these over the last 15 years which is where I learned most of what I know about working with Acrylic.It's a long time since I was stocking ICI Perspex as a distributor branch of a national company but production methods haven't changed since I saw them in action a number of times at the factories.
Its a track ballaster for model railways and lays the scale small stones (grit) in between the rails and at either side of the rails. They were mainly laser cut but the grooves that sat on the rails in the base were critical for correct operation in terms of width, depth and shape, these were routed.Is that a dispenser of some sort John and what's in it?
I absolutely hated extruded acrylic, i received some in an order for the ballasters and was horrific with stress cracks all over the place after a few days. The whole batch of ballast spreaders had to be scrapped, i had cut a complete 1220 x 2440 sheet on the laser taking 2 days, it all ended up in the bin, never again.My personal experience of routing is the same as yours, extruded can melt very quickly with a router if you aren't careful but it bends much easier using a simple line bender. Also flame polishing the edges is far better using cast.
When I first got my laser cutter I bought 1.2 tonnes of 4 mm medite (laser compatible mdf) it was a great material for prototyping items and it took years to use up my supplies, like you say, it was a sad day when I had to buy more. These used up my last supplies rapidlyI left the industry more than 30 years ago and still have a stock of offcuts I'm slowly using up. I'll be sorry when it's all gone and I'm forced to buy it.
