Phil Pascoe
Interesting - I don't use a breadmaker but I used Dove's Farm once ............ and wouldn't use it again.
Tris":1x37lefw said:ALDI sometimes have spelt and rye flours in and they've been good in the machine, just be prepared for a sunken top on the loaf.
Steve Maskery":37ywvd62 said:Tris":37ywvd62 said:ALDI sometimes have spelt and rye flours in and they've been good in the machine, just be prepared for a sunken top on the loaf.
You should not get a sunken top. If that happens it is because the flour is not strong enough or the dough is too wet, so, given that that is the flour you are using, you need to add a bit more flour to stiffen it up.
This is why it matters what flour you use. The recipes are designed using Allinson's flour (I think) so for other brands the recipe is just a guide, to be modified as necessary.
Very little gluten in rye flour so the dough is pretty wet. The paddle is more of a mixer than the kneading blade for white bread flourDibs-h":3fg35kza said:Bearing in mind I don't have a breadmaker - why is there a separate paddle for rye flour (for the Panasonic)?
Dibs
Tris":1cp17x1o said:the recipe I use is for something more akin to German rye bread and uses no white flour at all.
I would be interested in the recipe for German black bread - if you make it in a bread machine, knowing which recipe setting to use would also be helpful e.g.it's like #5 wholewheat, but with xyz in the recipe (for me - for it to "work" it has to be foolproof).Steve Maskery":1qp4rqdc said:I like German black bread
