Phil Pascoe
Anywhere else will be a safer bet than B&Q etc.I used to live in Surrey, Champions and Alsfords will always be a safer bet than B&Q etc.
IMO
IMO
Good shout,Get engineered wood.
Good shout,
Here is what Adam is talking about machined-panels , no brainer.
Will need edging or framing as others suggested to cover the laminations
MRodent
There’s nothing difficult about using solid hardwoods to make a bookcase
If you want to buy ready machined boards cut to your exact size ready for you to joint together to a finished bookcase you are going to have to pay a premium price
The boards that i mentioned at B&Q were very nice oak straight and ready to use..i was impressed …I hadn’t realised that B&q did oak boards…but they were expensive.
The boards that i bought and pictured on page 1 cost £340
There was lots of material there
You could buy a thicknesser for £250 ish use it to convert your rough sawn timber then sell it for not much of a loss.
If you are only wanting to do the one job
This is the bookcase i made its 900mm wide 1200 high and 300 deep
Ian
LOL!Good shout,
I have a large cast iron planer thicknesser in my workshop however because of space resistrictions it difficult for me to use on large long boards.so i bought a metabo lunchbox style thicknesser which i can set up outside and plane long boards easily.
So for my bookcase project it was… cut up my rough sawn boards the day after collecting them from a barn type warehouse..they were said to be kiln dryed
Cut the boards roughly to size width wise and left 100mm over length
Pass through the thicknessor until clean
Make the bookcase with domino’s
Finish with osmo oil
It hasn’t moved that i can see.
The back actually is solid oak flooring boards (from B&q) 15mm thick …you can really see the back when the case is populated.
Total project time 3 days from rough sawn boards to finished case
I'll leave that for someone else to explain, as I'm off out.
But,
I think you need to re-think your ideas about the material called wood. It doesn't and will not ever have the working characteristics or dimensional stability of plastic.
It comes from a plant, a tree plant to avoid any confusion, which is subject to the variations of climate and growing conditions. Boards from it, even though they may look flat when fresh sawn or in the shop, can and frequently do twist cup and bow. This depends on many things including; how the tree is sawn up, if it has twisted in a spiral when it was growing or if it grew on a slope, and for the sake of pedants everywhere, other things of course.
Alright then.Yes, I'd say I knew that even before I bought my troublesome parana pine years ago, as described. I just want an end result that looks and acts pretty much like the many solid wooden or (engineered wood) objects in my house.
For 000s of years human beings have made things using solid wood and often these objects don't necessarily seem to twist, warp, bow, split or fall apart, even after 00s of years. It appears that in the UK in 2023, given the reality of what wood yards are selling, that building a bookshelves unit in solid wood is, or may be, fraught with difficulties. Hence one possible option of using engineered wood, whether ply or something else.
Alright then.
Ply is made from built up layers of rotary cut veneer, mostly cheap stuff with good stuff on the outsides, engineered wood is made of strips of solid wood glued together, like in a solid oak kitchen worktop.
If you want solid wood which isn't made of strips, but doesn't move, twist or shrink very much, you need to get riven wood, which is split from very high quality trees, but you'll have to do that yourself. Quatersawn wood is the next best option, but it can still be cut from trees which are spiral grown and may twist and still bow, but it won't cup.
If you want wood that is unlikely to move then use engineered wood, it can be less or vastly more expensive than unengineered wood.Yes, I'd say I knew that even before I bought my troublesome parana pine years ago, as described. I just want an end result that looks and acts pretty much like the many solid wooden or (engineered wood) objects in my house.
The reason being is google old growth trees that we used years ago. And the spindles we use now. Old growth fir was hard to hammer a nail through. There is hardly any available anymore unless they tear down an old building and mill up the beams. And then new growth fir . You can break a 1x2 over your knee. Try that with an old growth board and you would be at the hospital. The new wood has much wider growth rings allowing for more rapid moisture absorption. I would guess.Thanks... an earlier post in fact suggested B&Q oak boards... but in fact the site says this about all these boards: "Treatment is required to prevent warping and bowing, if left untreated timber will silver with age and move to create a different character". What's your experience been with these B&Q boards?
That question of treating wood to help reduce warping has also been discussed earlier in this thread.
Also, in the post before yours John Brown says he reckons a dedicated wood supplier, like Champions, will probably be better. At the moment I'm inclining towards 12 mm birch ply with a "front facing" made of some solid wood. There's a Champions local to me.
Provisionally I've got the impression that the ideal of solid wood bookcases is somewhat problematic in 2023! I may also try making a small one in solid and see how viable/practical that is.
