Any idea what this is ?
Steve Cavill
New member
10 Jun 2021
UK
Hi has anyone got any idea what this was used for ? Looks hand forged, about 8" long. Jaws only open a small amount and don't touch or overlap when closed. There's a groove cut into the face of the jaws making them look like a stripping tool ? Bye the way it's not a one off as I have three of them in slightly different sizes and handle designs although the jaws are the same on all three.
Thanks in advance
Steve c
    36 KB
    20 KB
    22.1 KB
    40.3 KB
    46.3 KB
    19 KB
    25.6 KB
Looks like they clip tight and lock on.
Other than that - no idea!
Got a blacksmith made look to them. They look like they are meant to lock on so the question is what did they hold. When you look at blacksmith's tongs the variety is almost endless. Tongs for every item and if they did not have the right ones then they made a set for the job in hand.
John
Could be a farrier tool? Possibly the mythical boy scout extractor?
I think the mouth is too open to be for clipping hooves but who knows. I have also never seen the handle ends shaped like that, so on balance, I think it have talked myself out of it being for torturing horses. "I'm not helping much, am I? "
As a complete guess and as you have 3 all very similer, they seem to be designed not to crush, they sqweeze down to a preset size, how do they put rings in animals noses? Could it be for that, the tongs hold the open hot ring which is then closed,,maybe you need to ask a Goth, they have rings in their noses,,,,and elsewhere Im told!
Someone had a pretty specific job in mind when they designed those pliers, but very unlikely to be anything veterinary, or if they are, they pre-date my career by a century or two! I can't imagine where/how you might use them anyway, unless for holding thick skin back from an incision, perhaps. But do they actually lock? It doesn't look to me like the ends overlap enough, in which case, eliminate that idea too. They are certainly not for emasculating calves or lambs, that particular torture instrument has wide, rounded double-action jaws that don't quite close together. They are designed to crush soft tissue without cutting the skin...
The rounded jaws look to me like they are for grasping something (very!) firmly & extracting it by rolling the tool down, a la nail puller principle...
Cheers,
Ian
Write your reply...
