Another lighting question
Chris152
26 Apr 2017
Cardiff
We put together a light workbench with storage on top today. We're looking to put a plug-in batten light above the bench, on the underside of the storage shelf. It's about 1.7m long, so the light could be up to near that length, tho about 4' would probably be plenty. We want about 6500k, but I'm struggling with how many lumens I can expect with a plug-in light. We had a quick look in B&Q when we got the wood cut, but about 1500L seemed to be the limit, and looking at Amazon makes my head spin (there are rather a lot and I really don't know what I'm looking for).
My eyesight's not what it was, so bright light is good - what would count as bright light (the kind that allows an old duffer to see small parts/ details) in this situation?
Thanks for any thoughts, C
Yes, stick a small fuse in the plug though - 1A more than enough but 3A are easier to find.
Personally would go for 'cool white' rather than 'daylight'.
In that length, you could probably get an LED batten up around 8,000 lumens even at 4000 Kelvin neutral white. (You get the highest outputs from cool white LEDs like your 6800K but personally I find them unpleasant). This would be a ferocious amount of light but if you divide the lumens by however many square metres it's shining on, still not as much as full sun.
2000 lumens per square metre would be considered very bright light for doing fiddly tasks on small, hard to see parts, but full sunlight is still much brighter than that.
My first impression is that 1500 lumens from a batten that size is low. 4,000 shouldn't be hard to get but you may need to buy something proper, not an amazon no-name.
Thanks both - I went ahead and ordered the one from Screwfix last night, collecting today. We'll see. (Well, we're report back on whether not that's the case...)
