Hi
I‘m not talking about wood turning gouges here, just typical woodworking gouges. I’d like to make a sash gouge to an accurate dimension.
Is the “sweep” of the gouge the same numbering as moulding planes? Eg based on 60deg of a circle in 16ths?
I guess its defined by the outside dimension if it’s out-cannel and the inside dimension if it’s in canne?
If I turned down a an O1 rod to the correct imperial dimension, drilled and reamed it, then cut off a portion with a slitting saw, would that work? Obviously I’d also have to grind an edge and a tang.
Steve
Steve
