Ransoman
Hello all,
I have very limited woodworking experience and this is my first ambitious build so please be gentle (hammer). Fortunately I have a fair selection of tools at my disposal.
The Breif:
My Girlfriend is a recently graduated professional artist and as she specialises in large works, her existing studio (a 4mx2.5m flatpack log cabin) just wasn't big enough. To get something big enough we would be looking at upwards of £5k so we decided to self build something with a budget of £2k.
We decided 6m by 4meters with a single sloping roof with 3m at the highest point would be the ideal size however after drawing up some rough plans and working out the wood sizes we dramatically reduced the cost by opting for 20' by 14' with a 9' high wall and 7' low wall.
The reason I am going between metric and imperial scales is because B&Q, where I did my original material specs, sell their wood in 1220mm by 2440mm (or 8' by 4') so I did my plans in Imperial. Unfortunately the wood I ordered from a local timber merchant was sold in imperial sizes and all boards were too small As you can imagine, this caused great frustration when I discovered this AFTER I had built a perfect base to 16" joist centers.
The spec:
The foundation is a pier style foundation (as the area is prone to flooding and close to large trees and consists of 15 100mm by 100mm posts sunk 40cm into the ground and set in post crete, topped up to ground level with Mastercrete. the posts are layed out in 3 rows of 5 along the longest dimension of the shed and each row supports a 20' 94mmx100mm "Skid". Damp is controlled via a piece of Damp proof course at the top of each post and a membrane sheet on the ground.
The base is 20' by 14' (6.1m by 4.27m) and constructed using 47mm 100mm c16 with joists at 16" spacing. Insulated with Knauf rockwool supported by a "Hammock" of roofing membrane and capped with a damp proof membrane. The floor itself is 18mm OSB3.
The walls use the same 47mm by 100mm c16 timber and are at 600mm spacing (at this stage I discovered my error with the wood and adjusted the joist spacing to compensate). These will be cladded in 9mm OSB3 on the outside, Wrapped in roofing membrane, then battoned and finally clad in whatever we can lay our hands on at a reasonable price.
The roof is again 47mm by 100mm c16 at 400mm spacing, topped with 12mm OSB3 and will have a 3 layer felt roof. I have yet to work out the angles but it it drops 600mm over 4270mm. One concern is that I may have underspecced the roof joists but it will be "Noggined" for re-inforcment and an additional support beam can be installed later if needed.
So, Big mistakes? Apart from the Imperial design - Metric materials problem, the only other real mistake was not measuring and marking the foundation properly so the rear row of posts were miles out resulting in 2 having to be moved.
I have attached pics of the progress so far. At the time of writing, the base is perfectly square and perfectly level, All 4 walls are standing and I am more than half way through installing the noggins. The whole structure is very rigid and sturdy. I am very happy with it so far but we are almost at our budget already :shock: - At least we have bought all materials although I have run short of c16!
Current build stats:
Days of work: 11
Screws used: 450+
Blood injuries: 2 (OSB splinters!)
Cups of tea/coffee consumed: lost count
Costs: £1600
The Breif:
The spec:
Days of work: 11
Screws used: 450+
Costs: £1600
