Alternative rails for dewalt plunge saws
HDC83
20 Jan 2021
Northern Ireland
Most know that the Dewalt rails are not great for joining together.
Here’s how I modified Makita rail for a cheaper alternative to using Festool rails.
I used a 12mm straight router bit with a 20mm guide bush.
I made a jig using off cuts of mdf,
the 20mm hole is offset 6mm to where I wanted the lip cut off.
Slow and steady single pass from right to left
Here’s the end result.
Of course for even cheaper guide rails you could gave gone for Triton , or cheaper yet Evolution rails.
Same technique would work to get a TS75 (Festool) running on a Makita rail (that lip stips you using the two together) - very useful if you want a more affordable 3m rail
