J-G
Clearly the unintended consequence of poor education - or a sloppy attitude to 'history' / 'past convention' !"clearly" or the offerer doesn't know the rule ;-)
TBH, Quora is the last place to find anything apart from opinion.They had a good argument about this over on Quora.
A few interesting opinions were shared but they got no further to agreeing than we have ....
https://www.quora.com/What-s-the-difference-between-a-bolt-and-a-machine-screw
Often for that purpose you have a locating ring that the bolt passes through or you can use a shouldered bolt with a ground finish.I thought a bolt was only partially threaded so that in principle it can be inserted in a clearance hole and restrict lateral movement between items being joined, the bolt providing a clamping force only.
I’ve had that colour problem with car paint. I was looking through VW shades of blue colour chart looking for a blue/grey, but found nothing, later I came across it in the 'greens'. I swear to this day that it was NEVER green.I have some 10mm diameter coach bolts that are threaded full length. In a similar vein I also have 5mm machine screws that are only partly threaded. Clearly the manufacturers haven't read the memo.There is obviously a market for these fixings otherwise they would not exist.
Perhaps the difference between bolts and machine screws cannot be so tidily defined. As an analogy the difference between the colours of blue and green are quite clear to most people When you start mixing them together you will get intermediary colours that some will class as being a blue and other a green. I know this to my cost . I had a customer insist that the 'duck egg blue' her kitchen was painted, was in fact green.![]()
Funnily enough in the Welsh language there used to be quite a blurred distinction between blues and greens.' Maes Glas' is translated as 'Green Field' though ;Glas' is now the word reserved for blue.I’ve had that colour problem with car paint. I was looking through VW shades of blue colour chart looking for a blue/grey, but found nothing, later I came across it in the 'greens'. I swear to this day that it was NEVER green.
Incidently, full-threaded coach 'bolts' are coach 'screws'. There are other coach screws that screw into timber (hex head)
Regarding the coach bolts and coach screws, I scanned two pages from the Nettelefold's 1927 catalogue which illustrates the terms used by this manufacture in their literature. When we order these items, we call the coach bolts, 'cup-square-square coach bolts'. The square actually fits the square hole in crooks and bands used on doors which means the nut is on the inside of the door and can't be unscrewed from outside. When we order coach screws, we normally have a choice of hexagon heads or square heads. The coach bolts now come with hexagon nuts. If we are on restoration work we change these nuts for square ones. We actually have a set of Britool eight-point sockets for use on square nuts.Funnily enough in the Welsh language there used to be quite a blurred distinction between blues and greens.' Maes Glas' is translated as 'Green Field' though ;Glas' is now the word reserved for blue.
As for the distinction between a coach screw and a coach bolt. many of the suppliers are referring to their fully threaded bolts as Carriage Bolts, though the supplier 'Kays' seems to be covering all the bases in describing them as: ' Carriage Bolt Cup Square Dome Head Coach Screws' However, I will carry on thinking of coach screws as beefed up woodscrews with a head that can be tightened with a spanner..
I’ve got boxes of machine screws and I reckon 50% of them are only partially threaded. Very very rare that I’ve needed anything over about 30mm long that had to be fully threaded. A die helps in these circumstances.Bolts are only partially threaded, machine screws are fully threaded for metal working, end of.
An awful lot of people make up their own names for stuff if that don’t know what it is. The Americans are particularly fond of doing this.Clearly the unintended consequence of poor education - or a sloppy attitude to 'history' / 'past convention' !
Yeah. On the one hand language is a living thing and new slang comes with every generation of kids. Nothing wrong with that. On the other hand some iliterate moron invents "deplaning" because they never heard anyone say "disembark" and the news media copy them ! Causes a wry smileAn awful lot of people make up their own names for stuff if that don’t know what it is. The Americans are particularly fond of doing this.Wood turners are also pretty good at mis naming stuff but some manufacturers don’t help.
Standard bi hex sockets also work with square nutsRegarding the coach bolts and coach screws, I scanned two pages from the Nettelefold's 1927 catalogue which illustrates the terms used by this manufacture in their literature. When we order these items, we call the coach bolts, 'cup-square-square coach bolts'. The square actually fits the square hole in crooks and bands used on doors which means the nut is on the inside of the door and can't be unscrewed from outside. When we order coach screws, we normally have a choice of hexagon heads or square heads. The coach bolts now come with hexagon nuts. If we are on restoration work we change these nuts for square ones. We actually have a set of Britool eight-point sockets for use on square nuts.
View attachment 174998View attachment 174999View attachment 175000
Totally agree. The phrase “Jam Packed” has been around for many decades until it was reported on the news some years ago about passengers on a train “Ram Packed”Yeah. On the one hand language is a living thing and new slang comes with every generation of kids. Nothing wrong with that. On the other hand some iliterate moron invents "deplaning" because they never heard anyone say "disembark" and the news media copy them ! Causes a wry smileor as my old headteacher used to say "opened their mouth and their brains fell out".
