Harryseaess
New member
Hi all, been lurking on here for a little while but signed up today.
I'm just getting getting in to woodworking, and by getting in to it I mean literally just starting out. I've made a few bits and pieces before but never anything special.
So this has brought me to buying a cheap second hand table saw (my first ever table saw!). The Workzone WZTS2000 which was from Aldi. I know it's nowhere near as good as more expensive makes/models but it's all I could afford right now and I thought it would be a good way to try a table saw before splashing out on a more expensive one in the future.
I've ensured the blade is 90 degrees and the table is level. I've measured from the mitre track to both the front and rear of the blade whilst it's at full height (measured using the same tooth) and the rear is out about 1mm more than the front.
I've watched multiple YouTube videos to see how to align and it looks pretty easy, but my saw has a big fixed blue case all around the top half and access is tricky. I'm also not sure what bolts I need to loosen to align the blade. Below are a few photos of the bottom, any guidance/advice as to how I align the blade would be much appreciated.
Thanks a lot guys.
Thanks a lot guys.
