....ordered on line and delivered free the next day. Had been away on hols but got it out of its box yesterday and started to use it....very impressed so far (....considering the price). A good buy....so many thanks for all the positive reviews.
If you get a decent blade from Tuffsaws you may well find that the drift disappearsCozzer":n7qqsdf3 said:I followed some instructions to establish the "drift", and marked the table top accordingly...and then found out that the supplied fence isn't adjustable.
Whether there's any leeway possible to adjust/spin the table around a few degrees, I'm not sure.....or, in fact, whether that would be a solution...?
pcb1962":3ol0hm5v said:If you get a decent blade from Tuffsaws you may well find that the drift disappearsCozzer":3ol0hm5v said:I followed some instructions to establish the "drift", and marked the table top accordingly...and then found out that the supplied fence isn't adjustable.
devonwoody":25rlahk7 said:My experience with bandsaws is not to worry about bearings, I just keep them away from the blade!!!!!!, the backside bearing is more critica,l perhaps you are pushing the timber through to hard, let the blade do the work?.
Cozzer":27ibzbor said:Right....managed to get outside and do a few cuts.
Drifting problem still there, but not as bad as with the original blade.
Is the answer to ignore the fence clamping system and just use a C clamp at either end to match the required angle instead?
The manual claims that the max size for a band on this machine is 12mm...but the wheel/tyre is only 17 or 18mm wide, so how could a 1/2" band be used if the teeth gullet is ideally meant to sit in the centre of the tyre?
Wouldn't that mean that the back edge of the blade would overhang the back of the wheel?.....or have I got the wrong end of the stick?!
I'd think 12mm more than enough for that size of saw.Cozzer":13rqjspu said:The manual claims that the max size for a band on this machine is 12mm...
phil.p":1rvd80cf said:I'd think 12mm more than enough for that size of saw.Cozzer":1rvd80cf said:The manual claims that the max size for a band on this machine is 12mm...
