Air source Heat Pumps any good?
They do work in properties that have been built to the required standards of very high insulation and extreme heat loss but are not good for a retrofit to many older properties and many of the sheds currently being thrown up.
This is a common misconception. We are in the process of a retrofit and our ASHP is working great in spite of us still not yet having any loft insulation in an old farmhouse. If you size the emitters right you can heat almost anything efficiently with a heat pump.
Until recently we were living in a barn also heated with a heat pump (GSHP). We lived there for 18 years and it was insulated well below todays standards but again zero problems and no problem with updates.
It's the bias in favour of very techie solutions which worries me.
Low tech gets little mention - top of the low tech list being insulation, draught exclusion, thick socks and underwear.
Given these you can reduce heating costs by only having a blast on when needed i.e. when you are in the room. In our cold kitchen I can switch a fan heater on when I'm in there making a cup of of tea and it warms me up within a few minutes. Then switch of when I leave. If the place is insulated this heat will stay a little longer. If the only heating available is say low temp under floor it'd have to be on for hours before I could go in and make a cup of tea in comfort, and it'd be wasted staying warm for hours after I left!
This is one of the unsung virtues of a wood-burner - I lit mine a bit back with mdf offcuts and they burn like a rocket, temperature in the room hitting 25º in about half an hour.
Exactly so. Whilst insulation makes the best of any heat internally, by not losing it so fast, a lack or presence of insulation affects how much any heat source has to produce.
A heat pump still extracts 3.5 - 4 units of energy for every 1 unit driving it.
A gas boiler will lose just as much heat from lack of insulation as any other form of heating in the same building.
Yes I agree, nice and simple form of heating but think modern world where people have a remote for everything and no mater how hard they try there is no woodburner with a remote or Wifi plus they need to put some effort in with cleaning and putting wood in which might be a step to far for many.
That’s not true - there’s lots of mention of that low tech list.
Here's one: https://energysavingtrust.org.uk/
Or just google https://www.google.com/search?q=hea...g1NTY0ajBqNKgCALACAA&sourceid=chrome&ie=UTF-8
We had www.geogreenpower.com round for a chat. Seemed OK
But by and large we seem to have decided against, until perhaps some future date when we have done lots of improvements including insulation etc
I got asked a question on the solar panel thread and instead of dragging that thread off course anymore thought it best to answer elsewhere.
ian33a
We used Dartmoor Energy in conjunction with Reco. Your right to look for a firm who know what they are doing as there are too many horror stories about installations by firms who dont. They are 'Heat Geek' trained which rather put my mind at ease. In a way our job was quite straight forward as there was no existing heating system so it was all designed to work as one. Feel free to PM if you want to discuss further
Interesting - which supplier did you use for the installation? (feel free to PM). If we go down that road I would want to find somebody who knows what they are doing.
Circumstances overtook us in the end: we were flooded out in Storm Babet and the insurance paid for a replacement oil boiler. Through the ‘Build Back Better’ scheme they also paid for (an external version) to be re-sited outside on a plinth. So no air pump for us.
I am now contemplating a small solar system for the successor to our flood wrecked garden shed - mains power would be too costly but a battery/inverter/solar might be an improvement on torch light!
Lets' be honest we probably all have a heat pump in the form of a fridge or freezer. The basics are not remotely techie but agree that some of the interfaces can be rather technical and probably unnecessarily so.
Yes, insulation does not get enough attention but suspect that because its not very glamorous and oddly it seems many like a tech solution over the doing the basics. Still working on our farmhouse and adding good levels of insulation were we can. Lots of PIR and mineral wool going in (pics below)
Whether or not people buy into being 'green' gas and oil supplies are finite so sooner or later we are all going to need an alternative heating system. Heat pumps run off renewable electricity looks like our best bet at present
    99.1 KB
    98.2 KB
    139.6 KB
An air source heat pump is just a big fan heater - that also does cooling on those red hot days; can control the humidity sufficient to prevent moulds; provides an air flow through a house, which also prevents moulds; filters out pollen and other tiny-particle pollutants as it draws outside air in to heat or cool. You can also control it to a far greater degree than any fan heater. And it runs at a quarter of the e-cost of a fan heater for the same amount of heat provision.
If you burn MDF, plywood or any other man-made board-stuff on a wood burner you're a major polluter, not just of your neighbours air but your own internal house air. In fact, numerous studies show that the level of pollution from a wood burner inside a house is many times that outside just downwind of the chimney. You may not notice it but its there. You may even be one of the luckier ones who don't die early from it but instead just have a degraded condition of health. Still, why introduce a killer-machine into the hoose just to save a bit of capital? Well, difficult if there's no capital and the wood burner's already there. But burning MDF ..... ?
Yebbut they are not a major investment.
Well it is tempting. In our house the pump could go on the back wall with pipes going straight up to the tank in the attic. The whole thing fitted with minimal disruption - very different from whole house insulation!
But carbon zero.
..... But burning MDF ..... ?
er..why not? It's very dry, burns hot and clean, probably much less polluting than damp logs. Anyway it's got to go somewhere so it might as well be up my chimney!
But carbon zero.
Do you subscribe to the hope that burning wood is somehow carbon neutral? It might be if the planting/growth rate replaced the burn rate but that equation failed decades ago and is getting worse for the forests and woods as each year passes. A comforting myth and no more, now, for the wood burners.
The MDF and other man-made boards have a large percentage of not very healthy chemicals in 'em. These too fog your neighbourhood, perhaps stunting bairns and doing for grandpa who already has a dodgy lung. They also gas-up your living room air with the nasties.
I know, I know - we humans survived for millennia burning the logs. On the other hand, how much did that contribute to the rather low human life expectancy rates, along with the other new-born grim reapers stalking the biosphere post-hunter/gather life?
It certainly is carbon neutral if it's waste, wherever it came from originally. It will end up in the environment anyway, if not up my chimney.
In fact most timber used as wood comes from "farmed" sources. The big clearances are for agriculture, not fuel.
Formaldehyde apparently, in very small quantities. Formula CH2O, in a hot fire is going to turn into CO2 and H2O
human life expectancy rates have never been higher, although rumoured to have plateaued in recent years.
I think we need high efficiency clean wood and waste burners for direct low tech heating and also disposal of waste. I burn a lot of paper and cardboard. Pity to waste it all in landfill, where it decomposes anyway.
I have been running the heat pump in my workshop (installed last year) (1500sqft) that is modern built with cavity walls to exceed the latest house standards for insulation all winter (It’s probably my grandad annex at some stage!) I run the workshop at a constant 14C and the house at an average of 21C using an LPG boiler. The original house was built in the 1930’s and has been extended and modernised with insulation added to walls, floors and roof space. It’s good but probably not as good as it would be had we just demolished the and rebuilt. I’ve been comparing the energy usage of each. The cost to run both when I factor in the size is about the same! In other words there is absolutely no cost saving what so ever. If I turned up my workshop to 21C I am sure it would cost more to heat it with the heat pump than LPG, that’s excluding my hot water which I don’t have in the workshop.
My conclusion is that the eco narrative that heat pumps are more efficient, cost effective and save money is well, complete twaddle. Gas is roughly 1/3 the price of electricity / KW, so for my money, I believe heat pumps are less efficient than my LPG gas boiler! I’ve compared KwH and also cost to arrive at this conclusion. I won’t be swapping my house over to a heat pump voluntarily despite having the plumbing and heating system complete redone to enable a heat pump to be hooked up without further work. (Pipes, etc all specified for a heat pump)
I’ve concluded that In the winter, when you need to heat your home the COP of a heat pump is much lower, and the SCOP (mine is 4,61 @35C water temperature which is what it’s set at and the COP at air 7C is 4.91) is just a pathetic measure. Nobody runs their heating in the middle of summer when the heat pump is at its most efficient. The better measure is the COP if they actually provided it when the external temperature drops to near zero, that’s when it’s working its hardest and least efficient. I think my heat pump runs at around 2 in the coldest periods ie below 7C. (I have given the full details of the heat pump and its SCOP in my thread of building the workshop, I had decided to use the workshop as a test bed for a heat pump before converting the house)
My conclusion is that the eco narrative that heat pumps are more efficient, cost effective and save money is well, complete twaddle. .....
It will become true when gas and fossil fuels no longer available and the only alternative is electricity. Either way electricity will have lower carbon footprint if there is enough wind, solar, hydro sources. This is the whole idea.
Does that not just create more ash than heat or is it just one of those things where they try and put you off so that you recycle it ? Our cardboard and paper goes into both compost and recycling but who knows what happens to it after it is collected.
I agree, which is why the house is setup to run with 35/40C flow water temperature. I now don’t expect it will be needed in my use of the house, but since I was installing UFH throughout which significantly limits what you can subsequently do to change pipework, I made everything ready. An additional cost, but for me the right thing to do for the house.
Hydrogen can’t be pumped through much of the existing infrastructure and most of the pipework would need replacing…..not in my lifetime! We don’t have the generation or distribution infrastructure for the electricity needed (about double what we have now) so that’s also not happening in the next 20~30 years. We’ve kicked back the banning of gas boilers from 2025 and I believe the new date will also be kicked back as reality sinks in.
Loads of heat very quickly. Good for fast warm up. Low grade paper (newspaper etc) and cardboard (brown corrugated) best as it creates least ash. Glossy mags etc will burn but have to be crumpled up as they contain a lot of chalk and make a lot of ash
I didn't realise how much it was recycled until I googled!
https://www.recyclenow.com/how-to-recycle/paper-recycling
https://www.gwp.co.uk/guides/how-is-cardboard-recycled/
A scull about the various information sources concerning MDF, particle board, chipboard and other man-made boards containing a lot of glue and other stuffs besides the wood will reveal an overwhelming case against burning them. In some places its also illegal, because of the pollutants. The people most at risk are those inside the house in which its burnt.
Personally I avoid the stuff as far as I can. I've used one sheet in the last 12 years, for jigs and the like, which are all still in the shed. Its skanky stuff really, although admittedly useful for some things. But its everywhere, these days.
There's more and more evidence that such stuffs have slow but unavoidable effects on good health. These effects can be hard to notice or quantify - yet they have been in the last few decades. Look it up yourself, from sources you trust. Burning it is probably the worst thing you can do with it. It isn't danger-free in the landfill, or even in yer wardrobe from Claptrappery-R-Us; but that's not as bad as turning it into smoke and gas then breathing in the cocktail.
I suppose you can argue that life expectancy has increased in the modern age, largely through medicine and better conditions/food of various kinds. This in no way reduces the danger of burning MDF or the careless use of many other toxic substances. On the other hand, who wants to live forever? Still, deliberate shortening of one's life to save a few groats now seems a poor equation. :)
I understand that laws may be in the offing to reduce or eliminate wood burning altogether in more densely populated areas, as was done with coal burning when the truly bad smog in London, in the 1950s, killed quite a few. What'll 'ee do then, eh? Get yer solar panels now; perhaps even a windmill!
