johnnyb
another vote for empire blue. reasonable quality. but definitely square from the factory. my Moore and Wright is a delight though.
It's not rocket science? No, of course not, but the straightness of the edge although presumed hadn't been mentioned at the time.Yes obviously. Hence the need to double check - first that the edge is straight and second by repeating the exercise on other parts of the same edge, or another one.
It's not rocket science.
I've used lengths of MFC 6" shelving as straight edges, with no problems.
Either buy a square that actually quotes an accuracy standard e.g. BS939 or DIN875, or go for a speed square where the accuracy of mass production works in your favour. Their construction means they hold their squareness well too.
Mitutoyo very good.Hi guys
Was wondering about Squares, combination/ carpenters/ engineering/ etc.
What company makes the most accurate (at a DIY,ers budget) I tried bacho, Presh, parkside, all are accurate in small size but the longer the rule the less accurate they become.
Can’t justify the 3 sum figure of a starrett, but is there any company with good accuracy?
You know a square is no good when you have two back to back and can see daylight down the middle.
You have overlooked the laws of probability.Holding two squares back to back and seeing daylight only tells you that one or both is out. Holding two squares back to back and not seeing daylight could mean that both are out but in opposite directions.
So do feel free to enlighten me.
If you pick up two squares at random, each has three possibilities: acute, correct or obtuse.
Thus, there are nine combinations (of combination square).
Three of those nine will show no daylight. One of those three has both squares correct but there is no way of determining which one.
Hence, if you use "lack of daylight" as your assessment criteria, you will select a bad square 2/3 of the time.
Compare to the other method suggested above, which selects a good square every time.
I've done many hours of marking, over many years, with similar Marples style squares and I doubt I've used the inside edge even once.......
An interesting comment on the J. Marples Trial 1 squares on their accuracy on the INSIDE edge. Many people don't realise that the standard applies to the inside edge not the outside, which we tend to use as much.
Yebbut how would you know?.....
I also have a granite surface plate and granite square, which I used when I was refurbishing my surface grinder, all accurate to <0.0001”.
Marking blue and a reference surface, a random pair of parallels do if another surface plate isn't to hand. I'd suggest reading up on Whitworth's method of hand scraping a set of cast iron surface plates, even if you never use it the underlying principles are often useful to bear in mind.Yebbut how would you know?
Cos it has a certificate wot says so. It was inspected by an inspector.Yebbut how would you know?
Assuming the OEM is such a bad manufacturer that there is not a common error, you are more likely to find if there is an error that it has been repeated as part of the manufacturing process and so when put back to back it is amplified so obvious. It is an easy method you can use just to see the obvious, it is not a method used in an inspection or calibration lab.Hence, if you use "lack of daylight" as your assessment criteria, you will select a bad square 2/3 of the time.
