Newbie_Neil
Hi Adam
When you use the Trend jig it's as simple either way. Now let's see, that means the Trend is easier than the Rat. :wink:
The jig operates identically in "rounded" and "square" mode.
All you do is slide out the centre pieces of the jig and reverse them for "square ends". It will add about 20 seconds to the initial set up. But if you always want "square" ends then you just leave them in the square position.
Once set, the time to make your cut is identical.
Neil
asleitch":3ikc4no1 said:ok, ok what I was trying to say, but it didn't really come across, is the Trend, seems "designed" to do rounded M/T, or it is if you are at full speed, wheras the rat, has to use square M/T unless you get very creative with rounding the tenons off!
Neil
