Mike.C
Before I reply to you all, are these two any better
Mike
Mike
TonyW,
Generally I agree with the suggestions put forward so far. I do feel however that all this may be a little too much information to try and act on in one go. In my view you need to address the issue you raised in your first post "..the pictures just look "dead" to me. " first. In other words back to basics. Listed below in my view are the key points you need to address.
RAW format in my opinion should be seen as the digital equivalent of the film negative. Jpeg could then be seen as the prints you would get from your chemist or photo shop. Quote from a great American landscape photographer "I have often said the negative is similar to a musician's score, and the print is the performance of that score. The negative comes to life only when "performed" as a print" (Ansel Adams).MrJay":3op5zmd6 said:The .RAW format has dubious advantages. If you're shooting for print then it's the format to use. By the time you've resampled your images from 10 billion megapixels down to something more appropriate for piccies to post on the web or print out at home though it's advantages are lost entirely. That and .RAW pictures are rather raw. The camera does a lot of post processing like noise reduction when you shoot in .jpg that it won't do with .RAW shots, leaving you with a lot of extra work in post processing. (oh and .RAW piccies eat hard drives for breakfast and if that wasn't enough .RAW isn't a standard format either, each manufacturer has it's own system, and as such is no use for archive).
Agree with this - that's one of the reasons for the success of forums such as this. So share the good and bad with those of similar interest and reserve the good just to impress your friends and relativesShare the good and bad. It's the bad one's you learn from and if you can't put your finger on what's wrong with them or how to avoid the problem then you're best asking.
You do need both skills to develop your imaging expertise and get the final visualised result but I believe that it is too easy to put too much reliance on post processing to get you out of sloppy habits.Learning basic post processing is every bit as important as learning the basic camera method. You need both.
Using the kind of flimsy tripod most people buy without using a cable release is asking for camera shake problems at slow shutter speeds. It is all too common to transmit shake in the physical action of pressing the shutter release by hand. If you light the 2 second fuse this will probably not be long enough to eliminate shake 10 seconds or more would be better. Of course by this time anything other than a static subject will have got up and walked awayTripod is definitely handy, cable release is optional as any half respectable newish camera will let you set a 2 second fuse, eliminating shake from man-handling the shutter button. Which isn't to say that sometimes a 2 second wait isn't a chuffing nuisance. Cable release is handy if you can find one that'll work with your camera (they're not standard anymore), but not the necessity they used to be (more's the pity).
Like the idea of setting assignments - after a week of dog portraits I bet you feel a little ruffBut yes, it's a lot to take on board. The best advice is keep practicing the basics and looking and learning from the shots you take. I'm somewhat in favor of setting myself assignments. A week of nothing but dog portraits for example.
devonwoody":2r4geozm said:If you are going to purchase imaging software, I recommend Paint Shop Pro X1.
Adobe elements is all right but the program does treat its users as infants!
Yes it is a wire mechanism either mechanical or electronic that trips the shutter.Mike.C":32k52spv said:Tony, would I be right in saying that a cable release is for want of a better description a wire that is used instead of the shutter button![]()
As a generalisation blurred shots are primarily caused by too slow a shutter speed; if you are taking hand held shots make sure the speed is greater than 1/60sec. You may need to set the aperture manually to do this, so get the manual out and find out about the different exposure modes. It isn't rocket science and you will soon pick it up.
Gidon,
I would find the fully automatic mode on you camera (and ensure exposure compensation is set to 0) and then check that you are happy with the pics
Mike.C":1fdq1gjz said:Some members have recommended that I keep the setting on auto until I get a bit more used to the camera. So with this in mind can I still make sure that the shutter speed is greater than 1/60sec, or will the auto mode over ride any setting I make?![]()
