Sawdust=manglitter
Shamefully I’ve not worked on any more of the TV cabinet/sideboard for a couple of years since the main cabinet was complete and living in the house. I could use the excuse of a lack of time or other priorities, but truthfully it’s more than likely because in the back of my mind I didn’t have the confidence to finish off the doors and drawers and didn’t want to fudge them up.
Well enough’s enough and the ‘client’ (SWMBO) at the very least wants the doors to be finished off!! I have been prohibited from starting any other projects until I’ve finished the doors, so best get cracking with them.
The mortise and tenon joinery is done on both door frames, and I’ve also just finished flattening and sanding the 10mm thick book-matched burr oak panel’s I bandsawed from a larger oak burr I have a couple of years ago.
Here are the oak burr panels after a spray of water to raise the grain between sanding grits...
Here’s one of the dry fit (but unplaned/unsanded etc) quarter swan oak door frame laid over the burr oak floating panel...
And here are the loose fit frames against the cabinet (please excuse the background mess)...
So as the ‘client’ found it difficult to picture my design suggestions so I offered to mock up the design using the Photoshop Mix app on the iPad (which is surprisingly easy to use, but time consuming) and here’s the result...
Anyways, I planned on using African Blackwood to make the handles, hopefully make hinges, and to also frame the oak burr floating panels. To finally we come to my question...
... based on the mortise and tenon joinery of the main frame I wasn’t sure if I should mitre the corners of the African Blackwood where they will be inset within the oak door frame (if that makes sense)? Based on someone else’s much greater experience than mine, would the wood movement of the oak door frame mean that the mitres would open up in future? If so, what would be the best method of insetting the African Blackwood frame? Note that the African Blackwood would likely only be 10mm wide and maybe 7 or 8mm thick. In my mind it will set off and emphasises the incredible grain of the oak burr panels, so I would like to incorporate them somehow, but would ideally like to prevent the opening up of gaps between the oak frame and the Blackwood due to seasonal movements etc. I’d love for this cabinet to last a lifetime, hence wanting to do a ‘proper’ job of it, something I can be proud of.
