Carl P
Cheshirechappie":39cfv1d6 said:It's very easy to either shear off the screw shank, destroy the screw slot or destroy the screwdriver tip doing this. Don't ask how I know....
Alas, I don't need to ask...
woodpig":1xl0yrbi said:I prefer Torx or better still, Square screws though, they're much easier to drive as they don't cam out like pozidrive.
Jelly":11nzhbbp said:Posi-Drive is basically a step backwards from slotted and Phillips head... "You know what would help drive awkward screw? Making it easier for the driver to cam out of the screw head"
bugbear":2fou2cxe said:Jelly":2fou2cxe said:Posi-Drive is basically a step backwards from slotted and Phillips head... "You know what would help drive awkward screw? Making it easier for the driver to cam out of the screw head"
Pozi drive is much less prone to cam out than Phillips; I recently replaced some Phillips machine screws with Pozi's so I could tighten them properly.
BugBear
bugbear":2a06clb3 said:Jelly":2a06clb3 said:Posi-Drive is basically a step backwards from slotted and Phillips head... "You know what would help drive awkward screw? Making it easier for the driver to cam out of the screw head"
BugBear
bugbear":14gcufd3 said:Pozi drive is much less prone to cam out than Phillips;
woodpig":29dm3mpl said:I bought a set of Robertson screwdrivers, a couple of sets of bits and half a dozen boxes of Robertson screws when I was on holiday in Canada about 15 years ago. I haven't bought any Pozidrive since. "Robbies" are very popular in the USA and Canada. Once you've tried them nothing else compares.
DTR":3dr49k9o said:bugbear":3dr49k9o said:Pozi drive is much less prone to cam out than Phillips;
I'm led to believe this is by design? Before electric drivers had torque clutches, Philips were designed to cam-out before ruining the screw. Pozi were designed not to cam out as they should be driven with the benefit of a torque clutch.
Having said that, it's easy enough to destroy either one :?
My b.i.l. worked as a joiner in NZ up to about 10 years ago (a bit of time perspective) and he told me they never used anything else.woodpig":2t3mumdt said:I bought a set of Robertson screwdrivers, a couple of sets of bits and half a dozen boxes of Robertson screws when I was on holiday in Canada about 15 years ago. I haven't bought any Pozidrive since. "Robbies" are very popular in the USA and Canada. Once you've tried them nothing else compares.
Rorschach":xyg5btrj said:If that was their design then it might work well when driving a new, well made screw into a properly piloted hole with a good driver bit. Fast forward a decade and it comes time to remove a poorly made screw put into a small or non-existent pilot hole and many years of paint, rust, swelling etc and what you have is a recipe for frustration and trouble.
A couple of weeks back I did some DIY that involved removing screws that had been in about 15 years, some were pozi, some were phillips, the pozi were much easier to remove by far.
woodpig":187trok9 said:Rorschach":187trok9 said:If that was their design then it might work well when driving a new, well made screw into a properly piloted hole with a good driver bit. Fast forward a decade and it comes time to remove a poorly made screw put into a small or non-existent pilot hole and many years of paint, rust, swelling etc and what you have is a recipe for frustration and trouble.
I had to take out the Philips screws holding our old shower unit together with mole grips. I only just managed it, the hammer and chisel were primed ...
woodpig":5k6uz9iu said:I had to take out the Philips screws holding our old shower unit together with mole grips. I only just managed it, the hammer and chisel were primed ...
Pete Maddex":22gjfc8z said:woodpig":22gjfc8z said:I had to take out the Philips screws holding our old shower unit together with mole grips. I only just managed it, the hammer and chisel were primed ...
Didn't you have a Philips screwdriver?
:wink:
