Adding a page border in sketchup
Buying Sketchup Pro is expensive unless you are doing a lot of stuff needing Layout or imports/exports from/to other programs - in which case, I wholeheartedly recommend it.
Before I had the Pro version, I most often used screenshots from the Free version and then edited these in another image processing application to get the result I wanted.
Although the quality of the text in the exported images wouldn't be as sharp, you could do it all in SketchUp.
Draw the border in SketchUp, export it using an appropriate standard view and Parallel Projection and then import that as a watermark background. Use Screen text for the text area. Export at a reasonably high res and use PNG for the export to avoid the image compression.
