HawkEye":1bfrn294 said:As most here will already know those sizes are designed to make you spend more on boards and there is an enormous amount of offcuts/wastage that you don't need which your spending money on. I worked out that I'm actually using around half of the wood I'm buying which is totally rediculous.
jasonB":10qnbdw3 said:If you do need a cut to size in London then South London Hardwoods will do it, not sure of costs, probably nothing if its just to chop a board in half so you can transport it, but I would expect a charge if cutting to finished dims.
Jason
kmhphoto":mym7qtxb said:I bought a sheet of oak veneered board from them last week and they charged £10+ vat to cut it into 7 pieces - that was the only way I could get it into a Smart ForTwo car!
karl":37y59kky said:I'm a bit confused here - B&Q do sheets of 18mm (2440 x 1220) for £14. First 4 cuts for free. No brainer really.
pren":28ydt52x said:Incidentially; how accurate are the cuts from B&Q? Would I need to allow for a few mm for errors?
