Newt - it's not 'avoiding an answer', it really is that space is curved. Think of something closer to home. Take a walk, in a 'straight line' on the surface of the earth. this walk isnt, in fact, a straight line because the earth is curved, even though it doesnt seem like it from our perspective.
Similiarly, if you dont stop, and keep going in this straigt line, you will eventually return to the spot you started from. Whichever direction you start off from, you will at some point end up, if you dont change your 'direction', at your initial poiint.
Although a little hard to fathom, there is a notion that this is exactly what would happen if you could set off in a straight line in space and keep going - if you had enough time to do it of course!
A similar, slightly cliched, question is to ask 'what is north of the north pole? The very question doesnt make sense, because there is nothing to *be* north of the north pole. What's outside the universe? Nothing, for the same reason, essentially. Parallel universes dont count herew either, as they are thought to exist in separate dimensions,,,,,,,Erm, i think.
Anyhoo, time to go to work,
Adam
