sparky
hello all
im curious about my 1/4" mortise chisel and what i should do. i got a set of MHG mortise chisels a while ago and they are fine tools (1/4" 3/8" 1/2"). just very hefty :shock: (they are in the same patter as the two cherries mortise chisels).
now the problem is with my 1/4" chisel. trying to use it with a grip toward the tip to start a cut is not fun since the handle is so large (it is very ackward and difficult because it is so top heavy) i use this size the most and it is the biggest pain to use.
so i was wondering about a solution. :-k should i put a new handle on it (which i have no clue how to do) Or should i look into a more reasonably sized mortise chisel (the lie nielsen came to mind)
does anyone out there use a LN mortise chisel...and if so how is it. i am impressed with their quality but recently i choose to get a set of Barr bench chisels rather than the LN because the LN seemed a bit dainty for my taste and that is my only concern if i were to go with the LN mortise chisel.
sorry for blabbing on like this :roll: but i am curious about your thoughts.
one other thought i had was to order a 1/4" mortise chisel from Barr...but i am not sure what that would look like or cost.
and yet another thought :roll: i know some people in this forum are fond of the english pattern mortise chisels from 'tools for working wood'
what say you... :?:
thanks in advance
sparky
what say you... :?:
thanks in advance
sparky
