A couple of questions for all those knowledgeable folk out there.
Firstly, over our side door, there is a small porch. Between the lintel and the tile hanging, there is some lead flashing which was held in place by some mastic compound presumably to allow for expansion and contraction of the metal. This has now deteriorated causing the flashing to slip and I have already had to push it back into position. At the same time, I removed most of the old mastic. The attached pictures show the problem.
The question is, should I try putting it back into position and use an exterior frame sealant to fill the gap and hold it in place or use cement pointing.
The second question relates to multi-purpose paints. I have to paint our up-and-over metal garage door plus touch up the paintwork on some balcony railings; both currently have gloss paint finishes. I’ve read recommendations for Bedec MSP and Zinsser Allcoat Exterior at various times and both seem to get reasonable reviews. I’m inclined to go for the Bedec as their gloss seems to be more widely available, e.g. through ToolStation, than the Zinsser. However, I’d welcome thoughts from our fraternity.
