Woody2Shoes
Impressive Member
I'm glad you decided to go for the grey!
I'm not sure how you're getting access, but you really need both hands free to work and you ideally need the lead at somewhere close to waist height. This isn't a job I'd want to try and do off a ladder.
It doesn't need to be perfectly flat before you offer it up to the slot - you can 'persuade' it very easily with gentle pressure from a firm thin flat object like a putty knife or a bolter chisel. Ideally you'll need a stick to dress the lead back flat against the tiles (without overdoing it and breaking the tile underneath DAMHIKT!) - the closer you can get to one of these, the better: http://www.1stsupplies.com/product/rt18 ... ick-beech/
Looking again at your photos, I think it was probably on the squint from the day it was installed - it seemed quite well attached at each end.
Best of luck!
PS your guru would want you to patinate the lead afterwards too..... 8)
Best of luck!
