StevieB
Hi,
My first registered post
I need to change the consumer unit in the house before wiring in my workshop. After reading around and considering the replies to my last post I am left with 4 questions :?
1) I plan to have a 3 MCB box in the shop fed by armoured cable from the house on a 45A MCB. This will contain a 6A lighting circuit, a 30A ring circuit and a spare for upgrades/extra kit. Obviously an RCD is essential, but do I need one on the main house consumer unit and one on the workshop box or is one on the workshop box sufficient?
2) What rating RCD is recommended? Screwfix do boxes with 63A/30mA and 80A/30mA RCDs.
3) My existing house electrics system has a single switch to turn off all electric to the house before the consumer unit (which is an old push fit fuse job). I plan to leave this in place and just replace the consumer unit. Do I therefore need a double pole isolator on the consumer unit? (I am assuming the DP does the same as the single switch between the mains and the old consumer unit... if it doesnt what does a DP isolator do
4) The existing old house consumer unit is big and chunky and I am worried when I fit a new one the existing wiring will be too short as the new unit will be smaller than the old one. Can I simply cut the wiring back and fit a row of junction boxes and thus extend the cable to the new consumer unit or is there a better way?
Many thanks for any help, and sorry these are not strictly woodworking related questions
hopefully once the wiring is sorted I can get in and start making sawdust!
Cheers,
Steve.
Cheers,
Steve.
