Paul Chapman
Thanks, Derek, interesting stuff.
Cheers :wink:
Paul
Cheers :wink:
Paul
That is what I had in mind. What stopped me was the idea of trying to do this with a 1/8" wide bevel!
Any idea how to do this efficiently (that is grind and hone the result so that it takes shavings AND may be re-honed)?
You could use a "guttered" blade, which has built in nickers.
Hi BB
Regards from Perth
Derek
Alf":2v3db6xg said:Wasn't that what Stephen Thomas (iirc) did for some #45 irons? Always fancied trying that but wouldn't know where to start.
Cheers, Alf
SMT":2v3db6xg said:Guttered irons were made for some old plow planes without spurs, think i saw a Phillips plow with a set on eBay, once. Basically, the iron has thin side rails on the upwards face. When the bevel is sharpened, the rails become integral spurs, because with the clearance angle, they actually now extend below the plane in which the rest of the iron cuts. It is not quite that simple in practice, however, for an easy running cutter. i found that it was necessary to reshape the end of the iron, so the spurs extend below the heel of the iron as well. At the cutting edge, it is essentially "H" shaped with the horizontal planing edge slightly behind the two vertical edges. The vertical edges are shaped with rounded entry, but to a keen edge everywhere. I used a piece of O-1 steel a bit thicker than a typical #45 iron, and ground the gutter on a surface grinder. From a point just below the clamp screw, on up, the gutters are ground off flush so the clamp and adjsuter can work normally. This shank part of the iron will never get used for cutting anyway.
Alf":vir4vk0s said:A surface grinder... This explains why not everyone's rushing to try it really, doesn't it?Could you do something with a milling machine I wonder? Not that I've got one of those either. :lol:
Cheers, Alf
Alf":2c03ta4k said:I'll be watching your experiments to that effect with interest.:wink:
