26 cubic feet of southern yellow pine
Mark
Looking forward to this, was only looking at your display cabinet yesterday, need some inspiration for a future project myself. I really liked that!
I am sure you have the necessary skills but just remember this is a workbench, so this time no making the stand several times to improve the 'grain direction'. :D
Mick
gasman":2k82d2q6 said:
So far the plans are as follows:
- a roubo-style bench similar to the one in Chris Schwartz's book. The top will be about 2400 x 650 x 90mm (but I need to get 3 widths out of the 300 mm SYP boards - I think it will be OK. Legs will be 125 x 125, height 900mm. I am going to put in a Veritas twin-screw vice instead of the leg-vice
- at the moment probably a Veritas tail vice which `i will make either a shoulder vice or more likely wagon vie from.
I can't find the PDF of how to install the Veritas tail vice - does anyone have a copy?
Was toying with a Moxon but actually am more tempted by a little bench on a bench - to do my inlaying etc on
Best regards
Mark
Not sure if this is the Veritas pdf you require?: http://www.axminster.co.uk/downloads/950966_manual.pdf
Two developments - first I have completed my bench on a bench... 2 photos attached here
I am basically delighted with this. It has 2 wooden threads on the vice with a little bit of slack to allow for some uneven clamping. The threads were made using the Axi thread cutter which, once I had a sharp cutter worked beautifully to cut the threads to an inch and a half.
3/4 inch holes for the dogs and I got some veritas pups which work well after waxing the holes. The handles are cut-offs from some 60mm turned teak I have just made 2 lamp standards out of. If anyone is interested I can post details of the 'garters' I made for each thread to hold the outer jaw captive.
Then, a long days work on Monday where we chopped up half the 26 feet of SYP into 30 boards each 2440x100x50, then thicknessed each down to about 45 mm - this has been amazingly efficient on the wood - because the original board were 4890 long (16 feet!) I got 2 lengths out of each so just of the original 5 boards will make both tops which will be 2440 x 100 x 650 or thereabouts
Also chopped up 3 of the remaining boards to the rest of then bench - so actually I bought 2 whole boards too many as it was all so efficient. How rarely does that happen?
Photos of progress shortly
Mark
    114.5 KB
    191.3 KB
Looking good. Personally, I'm not convinced about the benefits of a bench on a bench; but, your workmanship is excellent!
DT
I like the bench on bench idea- like a Nixon but with the added benefit of support for the dovetail tail board when marking pins. It brings the work much closer to the eyes and probably at a position where you can stand much more upright
With a bad back i think this bench is going to be invaluable for doing dovetails etc on wide boards - I love it already
Regards
Mark
It's kind of like this one I found then I just made it up. It measures 600 x 350 x 250 high
Also over the last couple of days I have laminated the legs... 900 x 48 x 100 glued together in 3's then run over the planer and through the thicknesser to get these 4 which are 140 x 98 x 900 each - chunky!
Mark
    31.8 KB
    147.6 KB
Laminating the top - these are some serious chunks of wood. 4 of the '4x2s' laminated together with titebond 3 placing the flattest smoothest sides together for the top
I have now done 3 of these so far:
I bought some more Bessey K clamps from this place http://www.toolsandtimber.co.uk - best price I could find by far - £125 for 4x300mm K clamps. The front 3 boards will be shortened as the tail vice will form the right hand 450mm or so
No idea how I will be able to manhandle the top when it is all jointed - it is going to weigh about 100 kg I think
Mark
    150 KB
    136 KB
