scooby
I've read the coarser waterstones, such as the 240 grit, take more effort to flatten. Will the method of using drywall screen or wet & dry work ok?
Do you like your 220? It may be the wider blades of #8 and #4 1/2 but my stone dishes really fast. This stone has made more negative work for me than any other. I have a kinda worn DMT which I use to check the bevel periodically, and I always have dish out after using the 220. :xI have a 220 King waterstone. I flatten it on 220 grit drywall screen.
Regards from Perth
Derek
Tony":32jcujrk said:I have a 240 and stopped using it pretty soon after purchase as it dished REALLY quickly (my 1000 and 6000 take about 20 times longer before they need flattening), wore down far too quickly and doesn't cut as well as my DMT course stone.
I wouldn't bother with the 240, buy a DMT instead and nver flatten it :wink:
scooby":350b4g8g said:How long is really quickly? I just something to remove nicks and forms a new bevel every so often, so I don't think I'll be using it day in day out.
I recently bought a Shapton 220 GlassStones and am impressed by how it wears. Though I still get some dishing with my wider blades. Flattening is as easy as a waterstone. I am still undecided if its better than my DMT.David C":2myz0c41 said:This is a difficult one.
I keep searching for a waterstone which will remove metal significantly faster than an 800 King, without losing shape too quickly.
David Charlesworth
Its a comany that makes nice diamond stones. Here is a link to the duosharp's which have diamond on 2 sides.Keefaz":2kbxgdg3 said:Excuse me for being thick, but what a DMT? I have one of these 240 grit stones and it does wear down very quickly indeed.
