Hi all,
I'm after some advise please. I've been asked to make some semi fitted furniture for my brother. They will paint it.
The first thing is a BUNKET type cube system. They have 2 kids (teenage) who want to be able to sit on the top of it - I think 100mm dense foam would be suitable. I have also convinced them a back rest would be better than the wall (as per the drawing).
I will extend the back panel up high, and then add some wedges at the appropriate angle, and then tack another bit of 18mm MDF over the top of the wedges to give a sort of false hollow drum style back. Which again will get foam upholstered and stuck with Velcro.
So, my big question:
In order to sustain the weight of 2 kids would 18mm mdf work? or do i need to upgrade to 22mm?
The bottom board will sit under the uprights..... the top board will sit ON top of the uprights so the support is is there for a top weght.
The uprights forming the cubes will be the full height and the cube shelves will be dominoed in (none adjustable).
Dimensions - rough idea at this stage. Overall span is 1700mm. Height is 740mm
Gap between uprights is 400mm (roughly)
Any feedback very welcome.
Thank You
Thank You
