Brian
I do not sell them more than 20-30 pcs.
But there is no feed back regarding this band saw.
My main consider is as you wrote operation cost and speed of cutting.
i check and with band saw you receive :
Roller guide (2 pieces) with two guiding grooves. Suited for fine-cutting saw blades No. 9 / 12 (Nr. 716066 / 716068)
2 saw blades (respectively 1x No. 9 and No. 12)
Sorry i will write in eur price
Than i cut al so with nr 5 and you have to buy
Roller guide 2 pcs is 87 eur and blade 24 eur
That is a lot now the band saw is not 1200 eur but 1311 eur
You know if for the cutting i spend less time that means cheaper product. But if the operation cost are to high
than i do not see any advance in this band saw. My be that you can cut 15 cm thick wood but in general
you can cut 7 cm oak with hegner scroll saw but we sll know it is not easy and fast.
i have at home Hegner scroll saw. But i have 2 project which i cut 20 pcs 3 days. a have to change a lot of blades but they are cheap
If i have this band saw and if it saw faster than scroll saw there is a good things that i buy it.
