Triggaaar":dppn2xb7 said:
Indeed, I am sure the Festool is a wonderful tool, there aren't many complaints - there was one on the Axminster site though, aparantly you can't really use it without the rail, as you can't see the blade, which apparantly makes cutting on thin (width not depth) pieces of timber tricky?
Yes, it's a bit of a problem, but since the Festool comes with a guide rail you'd normally use it on that.... On the other hand Bosch [
GKS55,
GKS65 and
GKS85] and Hilti [WSC 255-KE and WSC 265-KE] both do conventional saws which run on guide rails (the Hilti uses Festool-profile rails) or directly on the workpiece but which can also plunge. There are a few circumstances where the guide rail would gets in the way or where the job is really a bit too rough (such as in-situ cutting of floor/wall openings) where I'd hesitate to use a rail saw but if your work is primarily workshop type stuff it won't be a problem
petermillard":dppn2xb7 said:
The base of the saw is locked into the grooves of the rail, and you can use a stop to prevent kick-back. You can accurately set the depth of cut. To plunge cut a normal circular saw you have to completely slacken off the depth adjuster, so you have no control over the depth of cut.
Agreed, but there are some plunge saws around which don't return to home position on a spring. The two manufacturers named above make them. I'm certain they aren't alone.
Maybe I should get the Mafell.
I'd try one first; the guide rails are quite different - the rubber strip doesn't get cut on the Mafell, so doesn't act as a splinter guard. Their way around this is to have a 2mm preset for a scoring cut - but this means that you really have to clamp the rails for every cut, so not such a fast way of working.
I agree that the older Mafell saws certainly do work that way. The latest MT55cc
doesn't. It uses a sacrificial red rubber strip in exactly the same way that Festool does. Just like the Makita SP6000, the deWalt DW520S and the Hilti saws it will run on a Festool rail - although for a new purchaser surely that is hardly an issue.
The rail clamps are specific to Festool
So if going for a festool, what do you actually need? The base kit (£430), a second rail (seems pointless without) and clamps as well? and what else? It could go from being an expensive option to an unobtainable option.
Actually, they aren't. The self-same clamps are sold by Bosch under their name. What they are, though, is darned expensive! A basic useable kit is pretty much what Peter Millard has, i.e. a saw, 2 x 1400mm rails, 1 x 800mm rail, 2 x rail joiners and a pair of clamps. The guide rails need to have some sort of box or carrier made or bought to protect them as they are rather prone to corner dings. That lot will allow you to rip down 8 x 4ft sheets, trim doors to length, etc, but don't forget that you may also need a couple of extra blades (such as a rip blade)
RogerS":dppn2xb7 said:
I thought you'd set the depth, put the toe of the base onto the wood, and lower the rest of the saw into the wood whilst the blade is spinning (but not moving the saw forward). ......
The idea of trying to do that scares the s**t out of me. The chances of the saw digging in and then flying back t you blade spinning, soft flesh. It happens so so quickly, you simply don't have any chance of correcting or stopping it.
It's a bit like plunging through with a jig saw, Roger. It can be done if done
carefully but it shouldn't really be attempted by the inexperienced. It's how I used to take-up floor boards before getting a plunge saw. I've got to admit that the plunge saw is
much safer
For what it counts when (if) my 7 year old Hilti dies I'll probably replace it with a Mafell simply because the tool seems to be a typical Mafell - solidly engineered and durable. I've used Festools at work for a few years now and I'm just left with the impression that, rightly or wrongly, they are a bit fragile. Similarly I can't live with the plunge action of the DW, although that's a personal issue. At the end of the day, though, I'll still keep an old rip saw for rough work (and the odd pivot plunge cut :roll: ).
