Farmer Giles
The biggest tool in the box
I bought this drill a while ago but have only just got it up into the workshop from the barn below as it's a bit of a lump and it needed the head off another drill. I need to wire it up to my 3 phase 415v inverter in the next week or so and eventually it will receive a renovation including paint but for now I have need of it so it will be pressed into service.
The plan is to build a table and fence to cover the existing table that can easily be removed if I want to use it for metalwork. I have another drill I use for metalwork so I will only need to do this if I need the larger throat depth of this one.
I have a large piece of buffalo board already laminated with blue formica and I bought the rails and fence from Woodpecker ages ago. So it will be a supersized version of this.
But with an elongated sacrificial insert as its a radial arm drill, the radial arm is unusual as the path is not in one axis, the head swings around and can reach any part of the table, however I will use it in a similar fashion to a conventional radial arm drill mostly, and if I don't occasionally, I will use a bit of scrap to cover the bit of table I'm using.
I also have a deeper fence for drilling taller stuff
More when I get around to it.
Andy
Andy
