MikeJhn":2s2s3gsq said:
Phil
Sorry to ask, but is there a lesson to be learnt from this mishap, i.e make sure the clamps are done up tight or even don't remove the ZT plate whatever that is?
Mike
No need to apologies Mike. I've gone through it a few times in my mind since Monday and I think there's a couple of things.
The Z/T or zero tolerance plate was plastic on my saw with the gap around the blade being quite wide to allow the blade to tilt
at 45 degrees. I removed the Z/T plate a few years back for a home made one in hardwood. This doesn't allow for 45 degree cuts,
so that's when I remove it and use a piece of MDF or ply if I have.
I think the build up to what happened started when I made the decision to do too many things at once, instead of carrying on with the planters (
topic117949.html ) I thought it'd be nice to make a plant stand for our lass.
I don't know if they have a particular name, but imagine two letter "H" with a lap joint so they cross each other, and the plant pot then sits inside the frame. I prepared some Ash on the T/S, it was about 25 mm thick and I had to cut about 30 mm off the width. I rarely cut through timber in one go on the T/S, I tend to make a couple of shallow cuts either side so the blade is never higher than just over half the thickness of the timber being cut.
That way I can use two rubber backed plasterers floats to grip the wood and I'm well away from the blade.
At the same time I also decided to prep some timber for another job, and had done most of that leaving the cleat to be cut. Due to space, and having to keep moving things about, I'd put the T/S away once and then had to get it back out, this also involved moving all the timber from the planters that were stored on the T/S. Perhaps with all the moving about I'd started to rush things a little! Not paying enough attention and rushing.
It's also possible I didn't check the timber I was about to cut thoroughly enough, which I usually do. There were a few knots in it but nothing I thought would cause any issues as such. Although, I could have looked for a much wider piece keeping my hand well away from the blade. It really happened so quick I can't tell you how or exactly what happened. After seeing where the blade caught my ring, I did think that if had been another finger, as soon as I felt the blade I would have pulled my hand away, granted, it would have been cut, perhaps badly but not all the way through, and if it had, it would have been a clean cut. In that case, the finger could have been saved.
