Alexam
Bandsaw Boxmaker
AES":2dng9pf6 said:Hullo Alexam,
Yes, confirm, the foot switch that I posted here a week or two back for use with my Excali (which I'm pretty sure could be used for other makes of scroll saw and many other things too) is of the "momentary" type - i.e. press with the foot the saw runs; lift the foot off the saw stops. Note also that in the case of my Excali, the original ON/OFF switch is still active - i.e. until the ON/OFF switch is set to ON then the foot switch doesn't operate at all.
HTH
AES
I have just found that once connected to the new foot switch, that only works with the foot switch depressed and the start button on the machine has been pressed. When I lift my foot, the machine stops. However, I can only get the machine started again by depressing the foot switch AND pressing the start button. I am trying to find answers of how to get around the saw NVR at present.
