I have a pretty big space but just have everything on wheels so I can pull it out into the centre of the room. Make an adjustable outfeed table that can catch stuff from any of your machines and you'll have a lot of flexibility.
MattRoberts":3ev0b8cy said:Here you go
if you put it at the end you are limited to just drilling the end of a long piece and cannot drill the middle sectionratkinsonuk":2mpj4723 said:SteveF":2mpj4723 said:put the drill press in-line with chop saw
if you can get the height right so you can use the worktop for both
Steve
Cheers Steve. My original sketch had the drill on the end of the chop saw station, and that's probably where it would eventually end up depending on how things pan out. My ineptitude with the web version of SketchUp lead me to just dropping it 'wherever' for the purposes of the initial design.
A side question - has anyone bought one of the cheap £25 copies of SketchUp Pro from eBay and do they work or is it a con?
Cheers.
SteveF":2p9r8qvn said:if you put it at the end you are limited to just drilling the end of a long piece and cannot drill the middle section
think of it the like your chop saw where in an ideal world you would have 3.6m either side
but the drill would only need 1.8m
Steve
