The saga continues. Ok, it's a letdown as far as sagas go, it's just swapping out a plane.
I finished tarting up the record 8 over lunch so that I can sell it. I also reinstalled the original iron, and I ground off the bottom lip of the lever cap as a courtesy to the next person using it.
I didn't test to see if I moved the cap iron far from the edge if that would also alleviate the adjustment issue but even with the lip ground off, the iron is still hard adjusting forward, easy backward. It's still getting "held back" by the lever cap unless it's set in not all the way down on the frog screw, which is dippy.
Whatever. I now have another 8 lever cap to see if it's the lever cap itself, which has more of a hook shape than the flatter stanley lever cap. I'll do that shortly now that it's lunch.
That leads me to why I like to get later planes, or one of the reasons. I thought the plane that I bought would have a later frog design. That turned out not to be the case (OK). I don't remember the type - I think it's 13 based on the charts.
The knob looked spiffy = someone cleaned all of the finish off and waxed it. The handle looked really vintage which threw me off and guess what.
..no go. Doesn't fit the plane. which is OK, I have another handle that I made that fits, but makes it clear that the seller is just replacing bits and he must've cobbled things together for pictures or taken pictures that wouldn't show the handle doesn't fit.
I'll find the handle type - it's an older stanley, and someone on ebay will give coin for it.
the frog screws don't appear to be original - they just barely reach, and one spins (which was temporarily horrifying). It's only the first thread, and fishing longer stanley screws out of my deceased plane parts bin solved that.
The sole looked pretty flat, the iron is about 1/3rd used, but the sole itself shows the original milling marks (not a clean up) with no significant wear or scratches. I have a feeling that the cap iron and iron (which are nice) are from another plane. But with some luck, they actually are sweetheart types.
Removing the "low toe" took very little time because it was really just the toe and 10 or 15 minutes of initial work and the plane is <feeler flatness (but close in spots) until the last 1/4th of its length, and then the heel is quite high. This isn't so much a problem, but when it's several multiples of the feeler, it can be a little bit of an inconvenience for really close tolerance match planing. I'll live with it.
compare this to the type 20 that I set up a couple of weeks ago, which took a little bit of flattening, had no questionable parts and was flatter as new.
But.....is the new frankenstanley that the seller stuck me on easy adjusting? yes. it is. I could file the center out of the sole and make the whole thing dead flat end to end, but that would have to be for sport and ...well, no later buyer would ever think "parts plane, kind of junky, mismatches and nonoriginal parts. really flat".
Would be like a Vega with a fresh alignment.
