Graham Orm
You've had the pegs set wrong or the bush/cutter is wrong, one or the other. You sure the worktop is dead on 600? A lot are 616 and jigs usually have a hole for this. Maybe you've crossed over there somehow?
Or simply not pushed the jig onto the worktop properly, or it's slipped when clamping on. It only takes a tiny error to cause this.Grayorm":3krux35b said:You've had the pegs set wrong or the bush/cutter is wrong, one or the other.
From the photo that looks to be the problem. A small error of parallelism causes either the joint be tight and an increasing gap to run back from it or mate the long cuts and the joint is out.Grayorm":18zsg34o said:Agreed but the cut wouldn't be parallel.
Rhossydd":34qsgpg1 said:From the photo that looks to be the problem. A small error of parallelism causes either the joint be tight and an increasing gap to run back from it or mate the long cuts and the joint is out.Grayorm":34qsgpg1 said:Agreed but the cut wouldn't be parallel.
ColeyS1":3oftrtt1 said:Sounds like an ideal job for a sharp finely set smoothing plane.
Sent from my GT-I9300 using Tapatalk
