Hi Reg,
Just a few pointers for you,
If you must use a jigsaw be sure to have the proper type of blade.
Bosch T144DP are the right ones. They are thicker than normal,therefore helping keep the cut at 90 degrees.
Its generally not the machine but a flimsy blade that makes the cut wander.
Sorry Andy but downcut blades are for cutting 7mm laminate flooring.
I only ever use a jigsaw to finish cuts into the corners of the sink cut out.
Be very carefull drilling holes at the corners, as the laminate surface has a mind of its own and can blow out quite easily, again i dont do this.
Right heres what i do,
Place the sink where you want it, mask off around the sink so you can mark the tape and see it clearly.
I then use a circular saw with a 40 tooth blade to cut through the worktop.
If your saw has a riving guard, you will need to remove it for this And be very carefull,
or if you have a festool saw your laughing.
Line up the saw blade to the marked line and slowly and carefully plunge the saw through the worktop.
Cut along the line , remove the saw and do the same for all four sides.
Then take your jigsaw and cut the last bits into each corner,supporting the cutout so it doesnt fall out.
Perfect 90 degree cuts every time
:wink:
Then apply silicone sealant to the exposed edges.
HTH
Gary.
