MikeG.
What the buildings are made of is almost entirely irrelevant. Other than in certain designated areas (including national parks) you can cover up to half of your land with outbuildings (so long as they are behind the front of the house), without Planning Permission, so long as each individual building falls within the various dimensions given for Permitted Development. I would always advise clients to separate the two buildings, even if by only a few inches, such that they could never be construed as one.
The 7.5 x 4 m workshop was obviously given as an example such that it falls outside the purview of Building Control. Please note that this is determined on internal floor area, not the footprint, so you can actually build slightly bigger than the suggested size without needing inspection. On a practical note, I would suggest going for something slightly wider than this, and shorter if necessary to compensate. Planning a workshop is just easier with a wider space. 4.8 metres roof spans are easily achievable with standard timber sizes, but over that it gets a bit more complex, so I'd suggest heading towards that dimension for your width if that fits with the area you have available. With about 150 for wall thickness, that would give you an internal width of some 4.5m, which would lead to a max. length of about 6.6 metres.
However, as I've said previously, if you use blocks for your walls you'll end up wasting a lot more space because you'll then have to add insulation. Timber frame produces a much narrower wall.
