Workshop re-org - 1/3rd of the way through
LarryS.
20 Nov 2007
So my little workshop has been getting more and more crammed over the year since I first opened it. Lots of bottles of glues and wax, hand tools, screws, fittings, cloths, books, clamps, jigs, wood samples e.t.c e.t.c. e.t.c. All jammed into corners, piled on top of each other and so on. Worst point of this being that the workbench was the easiest place to store stuff, so became unusable.
As a reminder its layout is like this :
pink is a window, black are the two door entrances
Problem was that apart from one wall unit that must have come out of the kitchen at some point there was no spare cupboard space, and that wall unit had started to sag badly under the weight :
and there was a lot of wall space taken up by a fairly small amount of tools and the big dust extractor :
therefore as I've now been tasked with replacing the old kitchen (we moved into here just over a year ago now) thought that ideal time to add cupboard space to the workshop. So I copied a technique I saw somewhere with a rail attached to the wall :
that rail has its top cut at 45 degrees, then an opposing piece cut and attached to the cupboards as they've come out of the kitchen :
so this is as far as I've gotten so far :
as you can see I have also moved the extractor into the corner. Plan is to run some solid pipe from it to the different points its needed round the workshop rather than my old solution of a flexible pipe draped along the floor. Also will be painting the cupboard doors white to try and keep as much light as possible.
Also plan is to dedicate each cupboard to a specific type of activity, to save me spending half my time hunting round the shop !
Good use of space Paul. Looks like your shop is roughly the same shape and size of mine. I really need to have a sort out. I really wish I'd sorted out my floor last year. Probably won't get round to it this :roll:
Good thinking, Paul. :)
I also like the way you define your offcuts as "samples" - that must be how you justify your needs to save even the smallest piece of timber and throw nothing away! :D :wink:
This is looking good...have you done a drawing of the new setting out? (Or is it just a tidy up with no great re-organisation?).
I can see why your wife/ partner is after a new kitchen!!! :D
Mike
Mike
nope no drawing, did try but just couldn't be sure it would work in reality (because of the strange shape).
Thinking is that as all of my big tools are mobile (table-saw, bandsaw, mitre saw) on purpose built cabinets and I've put the wall cabinets on the railing system - this means that everything is movable, so for the first couple of weeks in the shop I'll see what works best where (by moving things around) and then call those the final positions. Part of which is to work out where to build my new workbench (which won't be movable) :
a. where the original one is by the window
b. underneath the wall cabinets
c. on the right hand-side wall
I must admit that I have a full scaled drawing of my shop and everything that's in it. But I'll be blown if I can find the perfect layout. It's trial and error. Which is why everything in the small/medium workshop should be on wheels.
Nothing is on wheels in mine......and it all works. Its about not having too much stuff!!! :D ......floor space is as valuable as machinery!
As for the bench.......without hesitating I would say it goes along the long straight wall on the right of your drawing, with the vice right in the middle of the wall-length. That way you can deal with long lengths of timber. But then, it is fighting for this prize location with the PT and the cross-cut saw.
Mike
hopefully i'll get some time out there tomorrow to finish off the main work (excluding the extractor system) and then i'll post some more pictures.
now going on a hunt through the workbench threads for some inspiration :D
